Proper mk7 4x4. (none of yr namby pamby AWD nonsense)
Re: Proper mk7 4x4. (none of yr namby pamby AWD nonsense)
Postby Airthies » Tue Nov 20, 2018 9:30 pm
twin--turbo wrote:so is this just RWD at present?
Yes. You can't rush these things you know
Need to sort out when I can get ramp time next though, but hopefully won't take as long as this epic task has...
But to be truthful after all this effort right now it's actually not any diferent from any other van in terms of function it's the same box but with an extra useless bit hanging on the back till I get my finger out an get the selector motor program working that's the next big push.
I'll be content enough for a while if I can get into low box.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby RustWidow » Tue Nov 20, 2018 9:37 pm
Great job, sorry it conked out
RustWidow
Postby Airthies » Tue Nov 20, 2018 9:52 pm
RustWidow wrote:Great job, sorry it conked out
Yea so was I thoroughly unimpressed you might say
And was fixed in minutes by pushing the main connector on the tank back in and making sure it was in properly
Drew fuel up through filter in seconds with the big vac pump and fired up on about 3rd attempt at cranking
All goo had it down the motorway to work n back this evo an feels fine and it's now silent when idling in neutral.
All in all so far so good.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Punto443 » Tue Nov 20, 2018 10:56 pm
Maybe it was 0548? :lol:
Did you find it?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Airthies » Wed Nov 21, 2018 12:10 am
Punto443 wrote:Maybe it was 0548?
Did you find it?
Was something like that I did find it after doing a bit more in-depth search
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Wed Dec 12, 2018 2:08 pm
So currently nothing practical has happened but it's feeling another now everything's settled in and loosened up after the box has been sitting stored for so long. It's just like it was before but with more hanging off the back of the box, it does have the slightest of pulsing when pulling away in first sometimes, but picked up a prop damper from a 2016 ranger so going to fit that and see if that does anything noticeable.
In other news I've been busy sorting out the ratio shift function.
So far got most of the program written but not sure if it will work or if I've missed out some fundimental bit of code
So if anyone's interested and knows what there looking at it'd be great to have a second opinion. ImageImageImageImage
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Wed Dec 12, 2018 3:38 pm
There's a prop balance function in ids, fook knows how it works though :lol:
Ids map here
loot
Postby twin--turbo » Wed Dec 12, 2018 9:11 pm
You said you foudn an updated ardublock, where at??
TT
twin--turbo
Postby loot » Wed Dec 12, 2018 10:55 pm
Ids map here
loot
Postby Airthies » Wed Dec 12, 2018 11:41 pm
Looked at them, handy things but I still have to write a program to work a controller to turn the relays on and off at the right time so unfortunately it solves one part but not the other
Have taken delivery of some transistors, some relays and think I've now got enough hardware to make it work. just not enough text in the right order to make the hardware do what it's told.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Thu Dec 13, 2018 1:53 am
Theres a company just along from Bam nut yard in kilsyth that maybe could help with what you need mate KELVINSIDE ELECTRONICS
ANDZ
andz327
Postby Airthies » Thu Dec 13, 2018 7:17 am
Oh that's handy, cheers.
Might of found someone to help so will see how I get on. Hardware side I'm pretty confident I can bodge that side of things
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Thu Dec 13, 2018 10:48 am
twin--turbo wrote:You said you foudn an updated ardublock, where at??
TT
Can't remember I'll see if I can find it again....
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Thu Dec 13, 2018 12:20 pm
TT
Think it's from here
http://blog.ardublock.com/engetting-sta ... ardublock/
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Thu Dec 13, 2018 3:28 pm
Ah so it isn't a simple case of 1 relay on next relay off then?
Ids map here
loot
