Hi all anyone know how the pin what holds the centrifugal filter in place is called and how it's fixed please my one seems to have come lose and the bottom part of it is either snapped or just rounded there is a thread on the bottom part of it but it looks like is snapped off and has been loose for a while and has bured over after time anyone know what's involved to fix this please any help would be grateful and part numbers would also be very handy for filter and the metal holding pin if anyone knows them thanks all
T350 LWB 2.2 RWD 125 BHP In silver with Air con and custom limited alloys Is the lattest addition..previous transits I've had R427 GBM reg 150 swb turbo smiley in yellow what a van 16 inch wheels rwd twin side loading doors and was rapid...
Overtightening the filter probarly pulled the threads You will have to remove the rocker cover and injectors to change it I have one here somewhere if you are having trouble locating one You can blank it off either but you willneed to change the rocker cover.
Thanks lads I went to Ford's this morning the part number is 6C814 they want 148.23 p for it plus the gaskets and seals seams a bit expensive to me
We're abouts are you bambi and how much would you want for it ?
haze wrote:We're abouts are you bambi and how much would you want for it ?
Im about 4 inches awaw from you.......................................on the map I will search in a while and get back to you later .You shouldnt need gaskets just injector washers and maybe 4 injector seals Give me till tonight
