Rear axle swap
Rear axle swap
Postby ballihoo » Tue Sep 18, 2018 8:54 pm
Evening,
Need to swap out my axle that keeps leaking at the seal behind the disc. Is there anything special needed or any surprises to look forward to.
How do I find how what ratio I have??
Mk7 2.2 t350 tipper 2014
ballihoo
Re: Rear axle swap
Postby knobby1 » Wed Sep 19, 2018 12:45 am
ballihoo wrote:Evening,
On what..?? Really helps if you tell us what vehicle you have..!!
Re: Rear axle swap
Postby ballihoo » Wed Sep 19, 2018 6:42 am
Ahh idiot. Rushing around! Sorry
It’s a mk7 2014 tipper. 125 crewcab.
ballihoo
Re: Rear axle swap
Postby knobby1 » Wed Sep 19, 2018 10:23 am
ballihoo wrote:Ahh idiot. Rushing around! Sorry
Ford Etis will show what ratio you have.
Re: Rear axle swap
Postby ballihoo » Thu Sep 20, 2018 6:29 pm
So I know my ratio and found a used one not to far from me.
What is the removing/ reinstalling like?
Do the brakes need to be bleed using the abs pump?
ballihoo
Re: Rear axle swap
Postby knobby1 » Thu Sep 20, 2018 10:44 pm
ballihoo wrote:So I know my ratio and found a used one not to far from me.
Not difficult, just time consuming...ideally bleeding should be done via IDS or Forscan...but can be done the normal way if you don't have access to the software etc...
Re: Rear axle swap
Postby twin--turbo » Sat Sep 22, 2018 7:59 am
Get new U-Bolts.
I picked up a new axle yesterday as mine is wining and 5.11....
Giving it to the garage to do as I expect they will get it done in no time.
twin--turbo
Re: Rear axle swap
Postby EDDY99 » Sat Sep 22, 2018 7:09 pm
Just done my axle swap and after bleeding brakes the pedal felt like a warped disc until I did an ABS bleed with IDS which cured it
MK 7 Transit 2006 (56) 2.4L Duratorq-TDCi (100PS) Series 1.7-350L
EDDY99
