Hi,
Im going to change the discs and pads on my van. i just wondered will I be able to lever the pistons back in the caliper or will i need a clamp to twist them back in?
Tom
Tpoles95 wrote:Hi,
Im going to change the discs and pads on my van. i just wondered will I be able to lever the pistons back in the caliper or will i need a clamp to twist them back in? Thanks Tom
Brains_transit wrote:They just push in and if your fluid is at max then it might overflow at the filler
I'd be more worried about him attempting changing discs if he think front pads need winding inBrains_transit wrote:They just push in and if your fluid is at max then it might overflow at the filler
