Probably coming on as daytime running lights, what happens when you switch side lights on ? If it reverts to only side lights it'll be daytime running lightsPuddle Jumper wrote:Hi all,1st post on here so here goes. When I turn the ignition on in my 2013 Mk7 the sidelights & headlights come on even though the switch is in the off position. Any ideas what to check or is this "normal"?
