_Andy wrote:If its dropped a valve then you need to look into that before getting into the injectors. Does it turn over on the starter, or is it seized?
lone wolf wrote:Looking forward to this thread, sadly i cant contribute but i will certainly learn as it goes along
£200 is a good price!
Sent from my SM-G925F using Tapatalk
Airthies wrote:What ps is the van? I'm guessing it's a RWD 2.4?
Start by getting the codes read. Snip
ned wrote:Black smoke is usually over fueling, is the knocking a diesel knock? You might have one or more injectors at fault.
knobby1 wrote:If it starts on the button and runs ok apart from a knock and smoke....it hasn't dropped a valve. Might just be something simple like poorly/loose injector clamps/copper seals.
How many miles on the beast..??
As mentioned by Airties, give it a good service/filters etc and go from there. There's plenty of helpful chaps on here to advise.
Mark R wrote:_Andy wrote:If its dropped a valve then you need to look into that before getting into the injectors. Does it turn over on the starter, or is it seized?
That's the strange thing it starts on the button and drives lovely, apart from the knocking and smoke, though to be fair there's only smoke once its warmed up or if I rev the engine.
Users browsing this forum: Google [Bot], reevco62
