hi chaps
ive got an 07. LWB 2.4. my lights wrk fine but as soon as I go to use full beam. it shuts my lights off.
any ideas ??
thanks
Airthies wrote:By "shuts off" what exactly does it shut off? Just the headlight beam? Or do you lose side lights and dash lights too?
When full beam is switched the system turns off dipped beam so if full beams not working the it will look like it's turned off your lights (cause it has).
Do you get full light on flash mode(pulling stalk towards you)?
or
does it just stay the same?
or
do you loose lights then too?
If yr side and dash lights stay on it could just be bulbs or fuses
No change there then it's tough being not so brightbambi mk 1 wrote:Airthies wrote:By "shuts off" what exactly does it shut off? Just the headlight beam? Or do you lose side lights and dash lights too?
or
or
I think the op has left you in the dark Iain
