However camshaft may be used old one or new one - it doesn't matter.eddy dar wrote: And im using the cams that were on the orginal failed head.
andz327 wrote:Did cylinder head come with top part of cam carrier? These are machine matched and puting different top on can cause the problem you have
Sent from my LG-H870 using Tapatalk
wojciech wrote:Cylinder head and frame form together holes for camshafts. Holes are machined with both parts put together and from this moment they make one part (inseparable set) with one number.
So: you'll be lucky if alien frame will fit cylinder head (concentric camshafts holes).
Look for picture - cylinder head and frame have been marked violet triangle (left upper picture corner) and appear on the list as one part with number 1701871.
https://www.catcar.info/ford/?lang=en&l ... I3Mg%3D%3DHowever camshaft may be used old one or new one - it doesn't matter.eddy dar wrote: And im using the cams that were on the orginal failed head.
Try check which one hole is nonconcentric and use (very carefully) adjustable reamer. It isn't best solution. Best is very expensive - new set 1701871, no chance for used, good, trusted set from ebay.
eddy dar wrote:Ive fitted head so i am not sure how i can check this now?
amlav wrote:You have to find out what's the issue with camshaft , otherwise it could heat up and seize up . Both camshafts should be able to turn by HAND with just a bit of force and should have a smooth and equal friction all around . Have a good look at the cam carrier with camshafts removed to see if there is a scored or broken surface on either carrier and camshafts . Unusual for the exhaust side to go wrong if timing chain jumped . It is mainly the inlet side that is mostly damaged .
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
