Mk7 heated front screen not working all the time
Postby iiPaul » Sat Sep 22, 2018 8:30 pm
So my mk7 transit has a a problem where the heated screen works when it wants too, it’s quite frustrating as I’ll push the button and sometimes it won’t work at all the screens completely cold all over, but I’ll do it another day and it’ll work fine as it should..
I haven’t had the van during the winter but wanna make sure it’s okay for the winter so I check it regularly but it’s very hit and miss, is there anything to check? I’ve checked all the connections, fueses and relays and what not but they’re all good, I know it’s had it’s a replacement front screen in it’s time, is this the cause?
iiPaul
Re: Mk7 heated front screen not working all the time
Postby andz327 » Sat Sep 22, 2018 8:51 pm
Check connections behind both A-post trims
Sent from my LG-H870 using Tapatalk
andz327
Postby iiPaul » Sun Sep 23, 2018 10:53 am
andz327 wrote:Check connections behind both A-post trims
I checked all four on both sides, power gets to them sometimes but not every time you push the button
iiPaul
Users browsing this forum: Bing [Bot], Majestic-12 [Bot]
