gfyffe1 wrote:You
hi, I have a 2004 mk6 transit laying up for a year on a hill pointing up , new battery fitted , new starter fitted, new glow plugs fitted, 2 relay changed and wire fixed. but still won't start
knobby1 wrote:gfyffe1 wrote:You
Have you read the codes..??
gfyffe1 wrote: l thanks for your relay i did buy reader but it didn't work on it not sure why, it was only a cheap 1 but it did say it should've worked but didn't (working on my other cars) what is happening is the glow plug light keeping flashing. that's why i changed those but no joy, I'm have nightmare with it. ANY HELP would greatly appreciated.
knobby1 wrote:gfyffe1 wrote: l thanks for your relay i did buy reader but it didn't work on it not sure why, it was only a cheap 1 but it did say it should've worked but didn't (working on my other cars) what is happening is the glow plug light keeping flashing. that's why i changed those but no joy, I'm have nightmare with it. ANY HELP would greatly appreciated.
What reader is it..?? Mk6 Transits are not OBD-ll compliant so most new readers will not work. F-Super is on that will....also Forscan and IDS.
ned wrote:Glow plug light flashing (is the eml) and will have stored a code, is there any fuel in the fuel filter? Have you tried easy start?
ned wrote:Is the pats light flashing when you try to start it (red light near the clock)
gfyffe1 wrote: i'm totally lost like this van has only 815000 miles.
knobby1 wrote:gfyffe1 wrote: i'm totally lost like this van has only 815000 miles.
If that's the case, she may be due an overhaul..!!
Are you saying she won't turn over at all or just won't kick into life..??
What reader is it..?? Mk6 Transits are not OBD-ll compliant so most new readers will not work. F-Super is one that will....also Forscan and IDS.
ned wrote:F super and elm327 can be picked up from eBay or scantool direct for less the 20sovs just make sure you get the elm327 for ford/Lincoln/mazda.
So does the van actually turn over or just clicks, maybe the starter is shot.
