xr4i_guy wrote:Problem is I don't believe that it was the new oil cooler that is the fault I took it off and pressure tested it and had no sign of leaks from it.
So I'm wondering if my problem is something else.
Ml Autos wrote:Hd same problem and replacing water pump fixed it. Good luck
karl wrote:Ml Autos wrote:Hd same problem and replacing water pump fixed it. Good luck
why replace the water pump ?
it has f*** all to do with the oil in water,.
oil in water is either the gasket on top of the pump or the shite steal gasket they use
bambi mk 1 wrote:are we talking about a fwd or rwd
bambi mk 1 wrote:Somebody needs to tell Karl a bit about rwd water pumps Oil has been running through them since 2000 AD
knobby1 wrote:bambi mk 1 wrote:Somebody needs to tell Karl a bit about rwd water pumps Oil has been running through them since 2000 AD
True, but the oil & coolant can't mix through the pump, the water pump body is just a way to supply oil and drain for the vacuum pump.
bambi mk 1 wrote:knobby1 wrote:bambi mk 1 wrote:Somebody needs to tell Karl a bit about rwd water pumps Oil has been running through them since 2000 AD
It can leak oil from a cracked oil gallery into the water Knobby
