Fitting side marker lights
Postby Lee J » Mon Aug 13, 2007 2:14 pm
I wanna be like the big boys - sob sob sob.
Saw a XLWB transit last month, the one with the orange (amber) marker lights down the side and thought "I need some of those for my LWB".
So, on saturday I got a set of 6 amber marker lights for my transit.
Thing is, what on earth do i drill a big hole in the side of me van with to take each light? the diameter of the bulb shaft is 24mm. I'd need to drill a 24mm hole in van, slide light in and pop rivit light to side of van?
1. Where would I tap the power for them from? sidelight circuit?
2. what would i drill the van with?
3. would pop riviting them crack them?
here's a piccy:
Transit Van - Gonna cost me a marriage if I'm not careful.
Lee J
Postby MrMPuk » Mon Aug 13, 2007 2:32 pm
When fitting all these extra lights have you fitted any relays?
Postby sc_BK » Mon Aug 13, 2007 2:44 pm
I'd have said that you'd be better off bolting them than riviting?
And are they LED or filament bulbs? If they're actual bulbs, you'll prolly want a relay from the sidelights, like mrmp says
As for drilling the holes - use a HSS holesaw but keep the speed RIGHT down, you don't want it getting hot. Also you may wanna use a slightly smaller holesaw (like 22/23mm) then file the last bit away to get a nice clean edge
sc_BK
Postby Lee J » Mon Aug 13, 2007 2:55 pm
MrMPuk wrote:When fitting all these extra lights have you fitted any relays?
not fitted them yet so no.
Where would the relay sit? I aint that good with wiring
Lee J
Postby MrMPuk » Mon Aug 13, 2007 3:00 pm
I ment all the other lights you've already fitted, because if you are adding more lights you will need relays.
Postby Lee J » Mon Aug 13, 2007 3:17 pm
oh right, I got 2 front roof markers and 2 rear roof markers already, no relay.
Anyone draw me a wiring diagram so i can add in the relay?
Lee J
Postby thunderider » Mon Aug 13, 2007 5:24 pm
im a big boy cuz i got marker lites,i took my power from the reg plate lites,and earthed off the roofs supports,i got flush fitting trailer lites so only had to drill small holes to screw and feed the wires.i didnt use any relays.
I am the god of hell fire.....
thunderider
Postby easymove recovery » Mon Aug 13, 2007 6:19 pm
led hardly use any power ive uprated to lrd number plate lights u dont need relays
EASY MOVE RECOVERY
VEHICLE TRANSPORTATION & 24 HR RECOVERY
NOTTINGHAMSHIRE BASED
easymove recovery
Postby MrMPuk » Mon Aug 13, 2007 9:18 pm
With the number of extra lights he has running he WILL need a relay.
Postby Luke » Mon Aug 13, 2007 11:00 pm
didnt guy88 draw somone a wiring diagram for this :?:
85 feed from side lights
86 earth
30 +ve from battery via fuse
87 to marker lights
Postby thunderider » Tue Aug 14, 2007 9:44 am
MrMPuk wrote:With the number of extra lights he has running he WILL need a relay.
who me?....the little orange ones on the front are reflectors
thunderider
Postby Lee J » Tue Aug 14, 2007 10:06 am
nah, I reckon I'll go the relay route to be safe. The four roof markers are NOT LED's and these 6 side markers are also not LED's so thats 10 extra bulbs running off the side lights. I will however take a feed off the number plate lights - good idea!
Lee J
Postby BigNeil » Tue Aug 14, 2007 10:38 am
Wow that does that make me one of the "big boys " great !!!!
But they came with the van :D
BigNeil
Postby MrMPuk » Tue Aug 14, 2007 12:03 pm
No.
Postby Lee J » Tue Aug 14, 2007 1:23 pm
each marker light has a red wire and a black wire. Can someone just suggest what to do with each wire? can i just attach them in a chan? if so, where does the last wire go?
[/img]
Lee J
