by lone ranger » Thu Oct 11, 2018 3:22 am
Hi members i,ve sorted out cutting out problem , it was my immobiliser the chip in the key , kept loosing its signal , so it cut out as if i had tuned the engine off that,s why when i unplugged relay it re-set the immobiliser ( note: that when heater plug light flashes it telling you that the immobiliser is active ) hope this helps : D
