ned wrote:It could be the slave cylinder, I believe the ones for dmf have less travel then the SMF ones, if you have the wrong CSC that could be your problem.
dumper wrote:Try reverse bleeding it you can do it by connecting a pipe from front brake calaper to slave cylinder with rubber pipe and using that to bleed it if not got the correct tool
Eddie78 wrote:ned wrote:It could be the slave cylinder, I believe the ones for dmf have less travel then the SMF ones, if you have the wrong CSC that could be your problem.
the one that was fitted and the one I replaced it with was "standard oem" 20.35m bore gen ford item.
Had quick look online and the only bore sizes I could see where 20.65mm which would give me a lighter pedal but less throw at the box end.
Dazzy92 wrote:I've had a few mk6 transits that's been the same with gear selecting, I've just went for lubricating the sh*t out the housing on too of the gearbox where gear cables connect. I've found they tend to dry up. So now I always make sure tits not dry.
As daft as it sounds if Mrs worked for me.
No..................................................................all mk 6 2.4 ARE RWDDazzy92 wrote: Or is all 2.4 mk6 rwd?
Dazzy92 wrote:Here a bet you're fun at parties eh, that's what a said, or you blind as well as old?
Dazzy92 wrote:School didny make me money pal, this isny school either it's a forum where it helps people that have questions, you're clearly no here for that so why no just get the nurse to put you to bed?
