maccavvy wrote:Garage have had it over a week.
Leak off tests are fine.
He's done a couple when warm and cold.
No air leaks in pipes .
No faults showing on any sensors.
But when turning over struggles to get pressure he says lazy/worn pump??
Vans done 190k and no history of being changed before.
What you guys reckon
bambi mk 1 wrote:Have you tried starting it on easy start Could be a simple thig like an ign switch
"He's done a couple when warm and cold"maccavvy wrote:Garage have had it over a week.
All valves are slightly different from each other and the pump learn is a procedure by which (and do correct me if I'm wrong here) the ECU fine tunes the current the scv needs to achieve the right rail pressures. The pilot learn fine tunes the pre-inyection to reduce vibration at low revs.maccavvy wrote:I've no idea what you mean by learns .
It is temperamental to start..generally it can be anything from 5 to 10 seconds of turning over.
When running it drives fine.
Sometimes when ticking over it goes into limp mode.
He said when cranking its about half the pressure it should be.
The SCV has been changed 6 months ago along with PRV.
This issue went from pain to start 1st thing. Slowly got worse to wouldn't even start last Monday. After being stood overnight
maccavvy wrote:nope... but doesnt explain lack of fuel pressure
