Boxster1 wrote:Hi
I have a Transit MK7 petrol/LPG with an Electric fan.
When I start the van from cold, the fans will kick in after about 15 mins driving.
i usually cover 150 - 200 miles per day. Both fans will run continuously the whole journey, switching between low speed and high speed.
I guess the resistors and relays can be ruled.
The van is showing no error codes.
I think a sensor somewhere is faulty. Having read many of the posts on this forum I am no closer to sorting the problem.
Can somebody please help.
Mike
What does your temp gauge read and what country are you in aas at this time of year in uk you'll struggle to get a fan on, my temp gauge sits a hair below halfway and it's been that way all year and its only when i put AC on that the fans kick in
Inside the cab on the right hand side of the heater box there's a little micro switch that clicks on AC when turn to screen de-mist ,maybe faulty switch, could unplug and see if it helps any
There's a unit between both fans on the cowling, the fan contoller if thars faulty it should show on diagnostics
Sent from my LG-H870 using Tapatalk
