Starting issues
Starting issues
Postby Antz86 » Wed Oct 10, 2018 9:08 pm
My transit mk7 2.2 56reg van broke down cut out twice before finally not starting back up again I had it towed home and mechanic said it was a injector I had this replaced and worked fine for 2 days broke down with alot of white smoke then was told egr was blocked and seized shut bought a new one now everytime I'm trying to start the van white smoke coming out of intake and engine Staking like it's blocked of something please help
Antz86
Re: Starting issues
Postby knobby1 » Wed Oct 10, 2018 10:18 pm
Antz86 wrote:My transit mk7 2.2 56reg van broke down cut out twice before finally not starting back up again I had it towed home and mechanic said it was a injector I had this replaced and worked fine for 2 days broke down with alot of white smoke then was told egr was blocked and seized shut bought a new one now everytime I'm trying to start the van white smoke coming out of intake and engine Staking like it's blocked of something please help
You'll need to get the codes read first.... and we can possibly advise after that. White smoke is usually unburnt fuel, so something is obviously amiss, an injector "leak-off" check is very usefull for diagnosing injector issues and is a good guide to their general health.
Re: Starting issues
Postby Antz86 » Tue Oct 16, 2018 7:13 pm
These are the faul codes
Antz86
Re: Starting issues
Postby Antz86 » Tue Oct 16, 2018 7:24 pm
Codes uploaded
Antz86
Re: Starting issues
Postby ned » Tue Oct 16, 2018 7:27 pm
The bottom code is from excess cranking I think,
Which injector was changed and by whom?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Starting issues
Postby bambi mk 1 » Tue Oct 16, 2018 7:35 pm
Check the timing :idea: The injector code can somehow pop up if the chain jumps .
bambi mk 1
