Air con stops working on MK7 2.2 63 plate
Postby Tvr123 » Fri Oct 12, 2018 3:17 pm
Hello,
I'm having trouble with the air con on my 2014 MK7 2.2 155 RWD transit, VIN WF0FXXTTFFDK84401.
It has done 231000kms.
It will work perfectly for about 5-10min, sometimes more, and will then stop working. By stops working I mean that it hardly blows through the vents. If I turn the fan right up it sounds like it's blowing hard (it makes a blowing noise as it should) but hardly any air comes out. If I put my hand to the vents they sort of feel cold but it's hard to tell.
It has been re-gassed and it's still the same.
I'd appreciate any help. I already took it to my local Ford garage and they said they couldn't find anything wrong with it which is ridiculous.
Thank you.
Tvr123
Re: Air con stops working on MK7 2.2 63 plate
Postby knobby1 » Sat Oct 13, 2018 8:16 am
Tvr123 wrote:Hello,
Thank you.
Sounds like the electronic "blend actuator" may have died.
Postby v8dave » Sun Oct 14, 2018 12:23 pm
Sounds like the heat exchanger matrix in the heater box is dirty, when the a/c is on it gets covered in frost which blocks it.
I only have information for transits up to 2011 but the ford diagnostics I have a copy of do not include a check that the heat exchanger is clean.
You can only get to it by removing the heater housing, which is a normally a full dashboard out job.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby bambi mk 1 » Sun Oct 14, 2018 12:37 pm
Has it got a pollen filter :?:
bambi mk 1
Users browsing this forum: Bing [Bot], TheCake
