Right here goes.. I have a mk7 transit lx.. cane with heated windscreen and switch etc, assuming it worked before I got my hands on it.
Last owner fried the engine so I put a mk6 engine in it, but because I have done away with the BCM and obviously changed the ECU. It won't work.
So am I right in saying if I just connect the wires from the swutch straight to relay it will work??
Obviously won't have the timer as that's in BCM.
