Wrapping Residue
Wrapping Residue
Postby goons » Sat Oct 13, 2018 9:41 am
Recently bought a white mk7. It was obviously wrapped/sign written in a previous life as there is a residue starting to show that gets blacker as time goes on. Can anyone recommend whats good for removing it?
goons
Re: Wrapping Residue
Postby dumper » Sat Oct 13, 2018 9:53 am
I’ve used panel wipe on small patches
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Fuel system troubles
Postby Airthies » Sat Oct 13, 2018 9:53 am
Some say tar remover, I find brake cleaner best.
Spay on a bit let it soften the glue then with a soft rag also soaked in brake clean, rub off glue. Ad more brake clean for stubborn old glue.
Also heard folk using wd40/petrol/nailpolish remover etc.(anything to soften the glue) but I'm not convinced they won't affect the paintwork more.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby ned » Sat Oct 13, 2018 10:03 am
Isopropanal alcohol works wonders :D
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby bigjohnthomas » Sat Oct 13, 2018 10:12 am
Where it's faded under the paint and keeps coming back through?
Bit of g3 and and old sock on it every time it comes back
Bloody pain 3 times I've got rid of "homeserve " off the front of mine
Then 6 Months or so later it's back again :x
Bloody ford
bigjohnthomas
Postby dumper » Sat Oct 13, 2018 11:12 am
ned wrote:Isopropanal alcohol works wonders :D
Is that for drinking while you clean the van ned :D
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby ned » Sat Oct 13, 2018 11:15 am
Yeah why not :lol: the more you drink the better it looks :wink:
ned
Postby Mad Husky » Sat Oct 13, 2018 1:09 pm
Mine says H&V 2000 all over it can't be bothered trying as some of the paint work is new other bits have faded got a polisher just too idle lol.
Mad Husky
Postby richgold » Sun Oct 14, 2018 10:37 am
As a courier thats worked for most firms I remove a livery at least once every 2 years. And I hate doing it.
Glue and tar remover is good, Isopropanol is better. Apply either with a rag to the reisdue and then use a cloth that has a thicker weave than a duster (like an old style dishcloth) to rub the stuff off as it will take more off with each stroke. Dont forget to wash the van well after as I've known paint to react if its left on there. Nothing too serious but it reflects light differently in the sun to the rest of the paint and water runs off it differently in the rain, if that makes sense.
It might want some t-cut or a mop after you get the gunk off as you will still be able to see what the old stickers said in the paint what with paint fading due to the sun. I spent ages t-cutting mine back to remove the UK Mail livery and like BJT says I can still see it in a certain light.
Im not having any more livery on my vans (like it says below!) as its too much of a bugger to remove.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
Postby crapmetal » Mon Oct 15, 2018 7:59 am
I'm a sign fitter and have to remove replace these stickers.
We mostly use turps to get off glue it takes a while sometimes especially if its starting to go black and has got covered in muck but with a soft cloth and enough effort you'll get it off. Putting it in a spay bottle helps.
You can use loads of solvents, most work, panel wipe or paint thinners is especially good. Wd40 does a pretty good job as does isopropanol.
If you're feeling flush avery do a glue removing solution for about £15 for 500ml that works great but stinks!
crapmetal
Postby ME » Tue Oct 16, 2018 11:00 pm
Lighter fuel from Poundland, the important part is the cloth you use to remove the glue residue, it needs to capture it rather than spread it around. Micro fibres are good. :?
Mercedes Vimto Premium
ME
Postby Punto443 » Tue Oct 16, 2018 11:23 pm
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
