Cider Andy wrote:Mine's got what I think will be spray-on insulation with fibreglass laid up on it in-situ. I doubt it will be easy to remove it completely but it might skim off like builder's foam once you've gut the GRP away.
Suits my purpose - I'm coverting to a camper, which needs insulating anyway.
Will you be left with a bloody great hole in the roof....?
bigjohnthomas wrote:i had the same unit as that without the stand by actually, hubbard
is it a freezer?
reversing valves n stuff ?
knighty1981 wrote:if your're doing man and a van type stuff are you not better off with something a bit bigger?
mwb seams an odd choice to me?
richgold wrote:knighty1981 wrote:if your're doing man and a van type stuff are you not better off with something a bit bigger?
This.^^
Also why would you want to remove the inside insualtion just to line it again with ply?? It looks to me that you wont gain much extra loadspace and its already lined for you. Its just a case of removing the chiller stuff and bunging up the holes or if you really must have it ply lined just glue ply to the lining it already has.
I wish my van had a wipe-clean waterproof lining like that and I cant understand why you'd want to get rid of it.
And the chiller stuff will have good value on ebay if you remove it carefully.
bigjohnthomas wrote:The fridge man told me that gah is Mr Hubbard initials
Sold Hubbard and set another company up
Grapefruit Armchair Hubbard is his name apparently
