Punto443 wrote:I used a spray foam stuff that you sprayed in through the pressure sensor tube. Worked well on her qashqai without removing it.
Sprayed it in, let it idle 15mins , take it for a enthusiastic run for 30mins, then done a forced regen.
Been ok for 2years.
Silver can, nor-something?
Most transit dpf issues are sure to a faulty vaporiser or wiring.
bigjohnthomas wrote:Use the code dude
Use the code
Punto443 wrote:I’m sure I only paid about £20 for it
It goes in the front pressure sensor tube before the dpf.
I don’t actually know where that is on the transits? I’ve only used it on her qq
oldyellar wrote:No joy with the spray stufg, so gutting it like a fish
Altransit wrote:oldyellar wrote:No joy with the spray stufg, so gutting it like a fish
Interested to see how you get on with that, as gutting a DPF should throw up a P244A code, and put it in limp mode
Users browsing this forum: Bing [Bot], knobby1
