Where to get a 2.4 engine, and possibly a 6 speed box?
Postby heartworm » Tue Oct 16, 2018 8:14 pm
My 2.4 tdci has given up on me, where is the best place to get a reconditioned/rebuilt engine from, where are the trusted suppliers?
Also looking to change the gearbox to a 6 speed while the engine is out as currently running around with a 5 speed box, and on the motorway would like a little more refinement.
heartworm
Re: Where to get a 2.4 engine, and possibly a 6 speed box?
Postby knobby1 » Wed Oct 17, 2018 12:27 am
heartworm wrote:My 2.4 tdci has given up on me, where is the best place to get a reconditioned/rebuilt engine from, where are the trusted suppliers?
Mk6 or Mk7..??
Postby heartworm » Wed Oct 17, 2018 6:23 am
Mrk 7 minibus, from when they first came out so the 2.4 engine with the 5 speed box, would like to change the box while changing the engine. Think it has bottom end failure.
heartworm
Postby dumper » Wed Oct 17, 2018 6:50 am
I think the 6 speed box just gives a better spread of gear ratios as the top gear on both gearboxes are the same ratio so to get an improvement you’ll need to do the axle ratio as well you maybe be better off looking for a Complete van with no mot or a damaged repairable to get all the parts you need if your van has a good body and worth doing
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby knobby1 » Wed Oct 17, 2018 10:14 am
dumper wrote:I think the 6 speed box just gives a better spread of gear ratios as the top gear on both gearboxes are the same ratio so to get an improvement you’ll need to do the axle ratio as well you maybe be better off looking for a Complete van with no mot or a damaged repairable to get all the parts you need if your van has a good body and worth doing
Yep, Dumper is correct, 1st gear is basically useless unles you like to climb trees.. :mrgreen:
Postby heartworm » Wed Oct 17, 2018 1:17 pm
ah cool no problem regarding the gear box, is there a reputable source for an engine, would rather go with someone with some decent reviews rather than a random ebay purchase.
heartworm
Postby Airthies » Wed Oct 17, 2018 8:12 pm
Member Karl on here builds engines.
memberlist.php?mode=viewprofile&u=71815
http://www.automotivemaintenanceservices.co.uk/
Give him a try first
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
