Any ideas..?
Any ideas..?
Postby Yachtsmark » Wed Oct 17, 2018 9:22 pm
Newby to this forum ..thanks for the great info resource.. 2011 mk 7 2.4 T 100
New injectors coded to vehicle ..clean start and idle until warm..then misfire(rough idle as shown with cylinder imbalance but pulls well on the road..SCV and PRV ? Tried a pump learn but failed due to insufficient fuel injected.
Yachtsmark
Re: Any ideas..?
Postby knobby1 » Thu Oct 18, 2018 2:26 am
If it fails the learns, it's often due to poorly injectors and/or duff SCV/PRV. Were the injectors actually new or remanufactured..??
Re: Any ideas..?
Postby Yachtsmark » Thu Oct 18, 2018 9:35 am
New Delphi injectors..runs vey rich/smoky at idle so suspect fuel pressure in the rail..Forscan shows 18750 Kpa at idle
PF Jones for PRV and SCV or original.? This is ex. Network Rail messing van, I think the injectors were Donald from
dirty fuel, ( tank/fuel lines all clean now.)it was barely drivable ..
Thanks for your help Knobby..
Yachtsmark
Re: Any ideas..?
Postby ned » Thu Oct 18, 2018 12:43 pm
Denso injectors you should have
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Any ideas..?
Postby Punto443 » Thu Oct 18, 2018 9:50 pm
2011 is euro4 and should be denso injectors
Frp qt idle should be 23000kpa and not deviate more than 2000
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: Any ideas..?
Postby bambi mk 1 » Thu Oct 18, 2018 10:02 pm
What mileage is on it :?: I have seen cylinder imbalance popping up with the timing chain ready to pop :wink:
bambi mk 1
Re: Any ideas..?
Postby Yachtsmark » Thu Oct 18, 2018 11:16 pm
..sorry yes Denso injectors ..mileage c.80k just done camchain, tensioner and follower.
FRP at idle hopefully shown below. Fuel pressure looks low @ 18750kpa ?
Thanks.
Yachtsmark
Re: Any ideas..?
Postby knobby1 » Fri Oct 19, 2018 12:57 am
Yachtsmark wrote:..sorry yes Denso injectors ..mileage c.80k just done camchain, tensioner and follower.
Thanks.
If it's low, you may have SCV and/or PRV issues.
Re: Any ideas..?
Postby daraioj » Fri Oct 19, 2018 6:43 am
Assuming your fuel lines are clean and the fuel filter is new I'd say replace the scv and do a pump learn.
Then test the PRV (under heavy acceleration frp should reach but not exceed 1600bar)
2010 2.4L RWD 100ps MT75 LWB High Roof
daraioj
Re: Any ideas..?
Postby v8dave » Fri Oct 19, 2018 8:32 pm
daraioj wrote:Assuming your fuel lines are clean and the fuel filter is new I'd say replace the scv and do a pump learn.
Fuel rail max pressure will depend on pcm calibration.
A 2011 van might be lower than 1600bar.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Re: Any ideas..?
Postby daraioj » Fri Oct 19, 2018 9:58 pm
Oh, I didn't know that. Thought that denso system worked on that range (230-1600) regardless of the calibration.
Any ideas why they would lower the max pressure?
Thanks for the input btw
daraioj
Re: Any ideas..?
Postby v8dave » Sat Oct 20, 2018 12:26 am
Earlier Mk7 transits may have gone as high as 2000bar but if there were too many warranty claims for problems caused by over fueling then one way to mitigate the issue would be reducing the rail pressure.
The denso system can be run with a fail open scv or a fail closed scv.
Ford chose the fail open option which requires a prv to protect the injectors and rail, but means the vehicle keeps running if the scv fails electrically.
v8dave
Re: Any ideas..?
Postby daraioj » Sat Oct 20, 2018 7:23 am
v8dave wrote:Earlier Mk7 transits may have gone as high as 2000bar but if there were too many warranty claims for problems caused by over fueling then one way to mitigate the issue would be reducing the rail pressure.
Interesting. Thanks again!!
daraioj
Re: Any ideas..?
Postby twin--turbo » Sat Oct 20, 2018 6:03 pm
PFJones supply genuine Denso at a third of the price of Ford.
twin--turbo
Re: Any ideas..?
Postby Yachtsmark » Wed Dec 05, 2018 12:07 am
Update..now idling correctly..
Took van to local diesel specialists ( who I rate from past jobs they’ve done for me..) they couldn’t get into the ecu to do a pump and pilot learn..so took it to main dealers (Gates) they said fuel pressure erratic and a leak at the pattern PRV I’d replaced, so took the original I’d taken off, to be re fitted by them..van now running well .
‘ Carry out pump and pilot learn, recalibrate injectors and learn factors, swap spigot for original..’
C.£114.00. Could have been worse.!
The scv I replaced was an EBay Denso..so must be ok .
So far- 4x injectors
SCV
PRV (leaked) pattern
Camchain, tensioner, follower
Oil/filter/fuel filter
Sump pan (old one rusted out)
1x breakdown when I stopped for fuel, flat battery symptoms, but I’m not convinced that’s the reason..ok after a charge.
Thanks for your input all..
Yachtsmark
