Does anyone know a fix for MK 6 clocks?
Postby dan83590 » Thu Oct 18, 2018 2:21 pm
My dials keep failing intermittently so I guess there is a joint or something gone on thw circuit board.
Speedo stops
Tacho stops
Temp gauge stops
Fuel ok
Give the clocks a whack and everything comes back on before failing again!
dan83590
Re: Does anyone know a fix for MK 6 clocks?
Postby ABA » Thu Oct 18, 2018 6:39 pm
yes common fault dash board / clocks need taking out and the solder joints on back of clocks needs touching up with solder basicly all down to dry joints
ABA
Postby dan83590 » Thu Oct 18, 2018 6:52 pm
Easily spotted or will I need to search for the dry joint myself?
dan83590
Postby knobby1 » Fri Oct 19, 2018 12:46 am
dan83590 wrote:Easily spotted or will I need to search for the dry joint myself?
Just do them all....they can be hard to spot.
Postby Mad Husky » Fri Oct 19, 2018 7:50 am
Did this on mine only did the ones where the power block went in it was easy and solved it for me.
Mad Husky
Postby dan83590 » Fri Oct 19, 2018 8:23 am
Lovely thanks. I'll give it a go this weekend.
dan83590
Postby Airthies » Fri Oct 19, 2018 7:24 pm
A Mk7
Sent from my anu5 using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby dan83590 » Tue Oct 23, 2018 2:47 pm
All sorted. A fairly easy job if you have a steady hand.
dan83590
Postby Altransit » Tue Oct 23, 2018 6:50 pm
Good result :D
Postby ned » Tue Oct 23, 2018 7:06 pm
Was/is there not a how to for this? If not maybe we need one as its asked quite a lot :D
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Altransit » Tue Oct 23, 2018 8:43 pm
I can't think why no-one pointed out the "how to" on this :roll: :P
:arrow: viewtopic.php?f=18&t=189785
:lol: :lol: :mrgreen:
Postby dan83590 » Tue Oct 23, 2018 8:58 pm
I did do a write up but I guess you deleted it. :(
:lol:
dan83590
Postby ned » Tue Oct 23, 2018 9:00 pm
dan83590 wrote:I did do a write up but I guess you deleted it. :(
:lol:
No your write up is now in the 'how to' section :wink:
ned
Postby bambi mk 1 » Tue Oct 23, 2018 9:04 pm
:lol:
So is the video Ned https://www.youtube.com/watch?v=NAd0WGf1ZhI
bambi mk 1
Postby dan83590 » Tue Oct 23, 2018 9:06 pm
:lol:
Cool.
dan83590
