twin--turbo wrote:Garage has swapped out my Whining 5.11 axle for a 3.73 on MY 100 T350..
It's lovely!
No drone, whine, it's actually quite quiet!!
Acceleration is still brisk enough, in fact it actually feels better as your not getting into 5th early.
2K RPMish at 62MPH ( Need to get the limiter deleted.)
The axle cost £150, and the fitting was £225.. I could technicaly have done the swap but it's a heavy lump and you have to blead the breaks and everything else and it's cold!!
Hopefully the lower RPM will give a bit of a fuel economy increas and over time it will pay for itself..
Well Happy...
Now just got to.
Fit my leather wheel.
Fit my rear 2 seater bench.
Find and fit a sliding glazed door ( now I can travel to pick one up in silence )
Rock on!!
TT
twin--turbo wrote:,,, it's a heavy lump ... and it's cold!!
Paulscarbs wrote:Did you (your mechanic) swap the whole unit or just the internals of the diff itself?
Paulscarbs wrote:Had a thought- Will result be comparable to axle swap?
