Reverse sensors
Reverse sensors
Postby Ashley S » Mon Oct 22, 2018 4:58 pm
Reversing lights fixed changed the reverse switch was broke. Now the reverse sensors don't work will it be a fuse or a switch? On a 2011 t350 mwb. Cheers.
Ashley S
Re: Reverse sensors
Postby Altransit » Mon Oct 22, 2018 6:25 pm
Do you get the long beep (which tells you they're not working) when you turn on the ignition?
Re: Reverse sensors
Postby Punto443 » Mon Oct 22, 2018 7:45 pm
Maybe you need to speak to PAM?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: Reverse sensors
Postby Ashley S » Mon Oct 22, 2018 8:03 pm
Altransit wrote:Do you get the long beep (which tells you they're not working) when you turn on the ignition?
Nope, not sure if they even work I know if I look behind the bumper there's sensors with wires etc..
I've owned the van 2 days so not sure if a fuse or something has gone.. it's never worked for me.
Ashley S
