Hey,
Iv had a few problems with the turbo on my mk7 2.4 140 rwd 350 van.
It started thowing codes for underboost and overboost etc
So after allot of research, i pulled it out and did a good variable vane clean as i found the control ring was getting stuck on the edges of the turbo, so i also ground out all the carbon/rust that was causing it to get stuck and its perfectly smooth now wothout any sticking points.
I also noticed some play in the hella actuator so i stipped that down and replaced the worm gear, shims and motor.
I had a really good feel of the bearing and there is next to no play and is really smooth.
So after putting it all back togeather and testing, i cant get it to throw the codes anymore but i have noticed a siren noise coming from the turbo side of the engine bay. (Im not sure if this was present before or not).
I instantly thought of a boost leak where iv put it back togeather, so iv been back in and replaced all the gaskets and seals, but no change to the siren sound.
So iv done some reading on this and people suggest a bearing failire? However the bearing does feel really good and iv checked in the intercooler and theres deffinetly no exess of oil in there. (Theres a light film of oil in the tubes, but iv put down to the crankcasebreather fumes)
Any ideas what else this siren noise could be or is it deffinetly the bearing?
And if so does it have to be a new turbo or can i just get a turbo cartridge?
Thanks guys!
