Brigadoon wrote:Hi Nobby.
Thanks for your reply.
Is this the valve on the side of the pump.If it is this was replaced when new short block was done about 7000 miles ago.
Thanks for the advice on the tow starting as I was not aware of that.I have only done it once and it started easily.
The electrical shop used ether squirted into the air cleaner.They advised that this is also not a good practise.
I have had to do this twice so I could move it.Will have to do this to get it to the mechanical shop.
When we put the new short block in we had a car doctor look to see if they could find what might have caused pistons to fail at 21000 miles.He reconed that it was the valve on the side of the pump and had this replaced it.He also went through all the injectors etc to Make sure things were ok.He also at the time said he had picked up a possible pending fault with
the ingnition key or ignition barrel I think,and said it would be wise to replace this.
I had forgotten about it until I had this problem.
I have told both lots of people that have had a go at fixing but they said that this has not shown up on their machines.
I have also tried spare key.
Many thanks again.
Brendan.
Brigadoon wrote:Hi Knobby.
Thanks again for your reply.
I have only started motor with easy-start twice. I just did what the electrical shop did.
Poll hose on the intake to the air cleaner and squirt for about 1 to 2 seconds while someone operates the starter.
And yes this starts easily.
Also once the motor is going there seems to be no problems.
I drove it home 500 km and it went like a dream. Did not switch it off for five hours.
When you say look at the ignition switch, do you mean the barrel that the key goes into?
Also it was the SCV that was replaced when short-block was fitted.
The car doctor seemed to think that this was the cause of the motor over heating the pistons and hence cracking and failure.
Unfortunately these motors do not have liners like a lot of the truck motors, so if you damage the bore they are through away.
I believe (from what reply's I got from this forum when motor blew) that this is a common fault with this year motor.
I was lead to believe that this 2.2 TDCI motor was developed by Ford,Fiat and I think Peugeot.I think they had pistol cracking problems at low mileage?
Not sure if the motor had an after market upgrade to a stronger piston? They could not tell me when new short-block was fitted.
Thanks again for your very appreciated views on this.I can at least go back to the "professionals" with some ideas.
Any other thoughts would be much appreciated thanks.
Cheers Brendan.
Gee that was a quick reply thanks.
Being down -under usually means a wait.
I am not mechanical enough to know where to look for the PRV but hopefully if I can get it to town (we live in the country) this week I will
pass on what you have told us to look for.
Your input is very much appreciated.
I am 70 years of age and I even surprise myself sometimes how I manage to "drive my computer" to find these sort of forums to get great information.
Cheers Brendan.
I have talked to the local Ford garage this morning,and have booked van to go in next week.The earliest they can see it.
I mentioned that I had been talking with you and that you had said that you thought that the PRV was one of the first thing we should look at.
They said that the PRV does not come on its own and that the whole rail has to be purchased? They have not told me the price but said it would be expensive.
Your thoughts on this would be appreciated.
Many thanks.
Brendan.
