fisherman99 wrote:If you blank it off it will not pass a mot if spotted by tester
bambi mk 1 wrote:fisherman99 wrote:If you blank it off it will not pass a mot if spotted by tester
He is a million miles away from a test station
OP if you remove the fan then remove the engine crossmember bolts from the chassis and drop the engine you will get at it without removing the engine Leave the rad and front in.
fisherman99 wrote:bambi mk 1 wrote:fisherman99 wrote:If you blank it off it will not pass a mot if spotted by tester
Sorry about that bambi but he doesn't say his location
Steve192 wrote:Euro 4 or 5?
ossie cossie wrote:yup im in OZ so no MOT,s here, would you suggest i clean it first before i blank it off, its a MK6 year 2004 where would i get a blanking plate? can i make one? anyone got the dimentions?
Users browsing this forum: Google [Bot], Majestic-12 [Bot], sfnett
