These any good? LIDL battery starter/charger
Postby wexican » Tue Nov 13, 2018 9:11 pm
Hi guys, we have a couple of Mk 7 buses with twin batterys and a while ago the batterys went flat and couldnt be started on a jump start.
My mechanic said if we'd disconnected one of the two batteries it should have started ok....
I've no idea which battery to disconnect or how?
Would this Lidl charger/starter be any good in an emergency? https://www.lidl.ie/en/special-offers.h ... leId=13460
Battery Charger with Jump Start Function ULG 12 B3
Can start engine with low battery without lengthy charging
For car and motorcycle batteries with 12V or 6V and 8-180Ah capacity
Program selection for recharging with optimal adaptation to battery type
Alternator tester for performance testing
Protected against reverse polarity, short circuit and overload
Intelligent microprocessor control with diagnostics programme and controlled charging process
Thnks, Mick
wexican
Re: These any good? LIDL battery starter/charger
Postby knobby1 » Tue Nov 13, 2018 9:18 pm
If the batteries are flat, either they're not charging or they're shot....how old are they..?? Have you had them properly load tested.??
Postby wexican » Tue Nov 13, 2018 9:26 pm
knobby1 wrote:If the batteries are flat, either they're not charging or they're shot....how old are they..?? Have you had them properly load tested.??
Everythings fine right now, tha twas a couple of years ago.
I'm just thinking ahead in case of emergency! Will get them tested before cold weather sets in though :D
wexican
Postby dumper » Tue Nov 13, 2018 10:31 pm
I got one for emergency use used it on my brothers doblo work well got him to work till new battery fitted thay have a 3 year warranty as well
Postby wexican » Tue Nov 13, 2018 10:40 pm
Thanks.
Still don't follow what the mechanic was talking about disconnecting one of the batteries to make it easier to start though. Anyone an idea on that ?
wexican
Postby Altransit » Tue Nov 13, 2018 11:48 pm
Disconnecting a completely dead battery from a twin battery setup, will give the other battery a fighting chance of starting the engine, unless it's in a similar condition :!:
Don't disconnect the red lead though :shock:
Postby wexican » Wed Nov 14, 2018 12:10 am
Disconnect the earth from the front one then? :| :(
wexican
Postby twin--turbo » Wed Nov 14, 2018 11:25 pm
My Front battery goes flatish over a few days to the point where the locking will not work and the trip meter looses it's distance. But it always starts of the rear battery fine.
I bought two identical replacements back in July but have had no inclination to fit them with it working as it does. (Just keep driving round with the extra weight!!!)
TT
twin--turbo
Postby dumper » Wed Nov 14, 2018 11:58 pm
twin--turbo wrote:My Front battery goes flatish over a few days to the point where the locking will not work and the trip meter looses it's distance. But it always starts of the rear battery fine.
TT
I did that with a microwave though I leve it till I decorated the kitchen so left it in the box till kitchen done 6 months later started to use it 15 months later it blow up and out of warranty had to buy a new one if I’d used it from day one it would have been replaced under warranty should have been quicker doing the painting :lol:
Postby wexican » Fri Nov 16, 2018 7:15 pm
Altransit wrote:Disconnecting a completely dead battery from a twin battery setup, will give the other battery a fighting chance of starting the engine, unless it's in a similar condition :!:
But will the front battery in the twin transit set up start the engine or do you have to connect it to the rear connectors? confused.com.......
I thought that front one was just for lights and radio etc.
wexican
Postby dumper » Fri Nov 16, 2018 10:22 pm
Yes but for starting they are linked together so it will pull the outher one down to the bad batteries level that’s why on twin battery set ups 12 v or 24 v you always replace them in pairs
