Hi guys, we have a couple of Mk 7 buses with twin batterys and a while ago the batterys went flat and couldnt be started on a jump start.
My mechanic said if we'd disconnected one of the two batteries it should have started ok....
I've no idea which battery to disconnect or how?
Would this Lidl charger/starter be any good in an emergency? https://www.lidl.ie/en/special-offers.h ... leId=13460
Battery Charger with Jump Start Function ULG 12 B3
Can start engine with low battery without lengthy charging
For car and motorcycle batteries with 12V or 6V and 8-180Ah capacity
Program selection for recharging with optimal adaptation to battery type
Alternator tester for performance testing
Protected against reverse polarity, short circuit and overload
Intelligent microprocessor control with diagnostics programme and controlled charging process
Thnks, Mick
