by scas » Wed Nov 14, 2018 5:37 pm
generally unless you have electric everything the plugs for the fog wiring wont be there, but its not hard to wire them thru a relay.also the escort ones have a slighty narrower screw fitting so you need to cut a tiny bracket out of a bit of tin or something
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
