camper-man wrote:Thanks for the advise
I don't know if the oil or water has mixed until I go and collect it later today but I will check if its got egr cooler pipe,Never done this job but it it has got a egr cooler pipe can it be done before a drive it home and are the pipes easy to joint together,Thanks again for any help you can give me.
knobby1 wrote:camper-man wrote:Thanks for the advise
What year model, FWD or RWD..?? It should have an EGR cooler but some don't have a water cooled EGR valve. If the cooler is leaking you'll possibly be seeing sweet smelling steam out the exhaust. If it's the oil cooler leaking you could have oil in the coolant or coolant in the oil....or both.
EGR cooler pipes can be connected together with a short pice of copper pipe to get you home, this will isolate the cooler itself. If RWD it's a pain to get at though as the cooler runs around the back of the cyl head.
camper-man wrote:Hi,Its a 2007 tourneo FWD am not collecting it now till Saturday bit of copper pipe is ready "15mm am thinking" I just want to get it back home "Driving" and not need to tow it 100mile
Just to check I have this right
If its got a water cooled egr I will remove the pipes and join them together
If its got oil in water -This could be the oil cooler Is that right?
Anything else I should check.
Thanks again am lost on mk7s been driving mk5s for so long
knobby1 wrote:camper-man wrote:Hi,Its a 2007 tourneo FWD am not collecting it now till Saturday bit of copper pipe is ready "15mm am thinking" I just want to get it back home "Driving" and not need to tow it 100mile
If you have a water cooled EGR valve, it will have coolant pipes to/from it, the EGR cooler assy is another separate item and will be in the passenger side of the cyl head, The EGR valve itself, while physically connected to the cooler assy, is separate. See here, the cooler is item 9F464, the EGR valve is item 9D475:
http://www.catcar.info/ford/?lang=en&l= ... U1MzUrMTMz
It's the two EGR "cooler" hoses you want to connect to each other not the Valve hoses, (if the EGR cooler itself is leaking).
Airthies wrote:I'd be checking the oil cooler again and a proper flush and clean then check for oil leaks, if it's had a cooler go but not cleaned out properly then there could be enough oil left in the system.
Also depends on cooler that's been replaced what condition or quality was it and finely it's possible to have a duff part straight out the box
