2008 2.2 FWD. Just fitted new Hub,Disc,Pads on nearside of Van all good. Drove Van round in the road NO lights on Dash all GOOD.The Drivers Side I had problems and eventually replaced Disc,Hub,Pads with new cable....In the process I broke the ABS sensor which fits behind rear Hub. Ordered a new Sensor bolted it in and fed the cable to the socket under van Back of the Axle. Put keys in ignition started up and without even moving.. I now have the ABS Dash light on also another yellow dash light with a pic of van with skid trails ? Also a 3rd yellow light with possible a question mark in the middle of it on the right hand side of the Speedo.
Its a new ABS sensor ! Does it need a LEARN to stop the Dash lights illuminating. I have checked connection several times all seems ok. Now I'm at a loss. Please give me a few ideas what went wrong.
I put a cheap code reader on and it said No faults ?
Do you think a fuse ?
What if I disconected the battery for a couple of mins do you think it would re-set the 3 Dash Lights
Do these replacement ABS Sensors have to have a Learn done.
Any helpfull info appriciated.
