Being a bit cheeky incase the question gets lost in the other thread and for easier future reference
I have a starter to flywheel issue
Was hoping to fit a flywheel that came with the diferent gearbox i have but it's larger diameter than the original so thought a starter with the stand off mounts would work but it's still too close to the flywheel.
Either got to find the right one or space out (bodge) the starter to the correct distance not holding out much hope for getting it sorted tomorrow
Anyone got any suggestions?
I'm kinda thinking it's too much of a miss match as it's the old 2.4 engine block and the newer 2.2/3.2 gearbox and reckon the bellhousing and block backplane are diferent sizes despite the bolt centres all working out ok.
The new flywheel ringgear Has an OD of 310mm (will add OD of old one shortly but it's a 2008 2.4 rwd 115ps)
Any ideas folks?
Sent from my anu5 using crapatalk
