Just after a big of info/guidance here.
I've got a 2.4 rwd lwb mk6 last night I noticed some white smoke while running, and when I went to restart it the engine turned over once and no more a couple Of times (as if the battery was flat, battery is fine)
Unfortunately I was about 50miles from home so attempted to nurse it home, after a while driving I started losing power suddenly and noticed the temp gauge had fired up into the red.
Pulled it over and turned it off. Overflow bottle was empty and any attempt to restart was just a click of the starter as if it had seized or hydraulic locked.
My gut feeling is headgasket failure but is there anything else I should look for?
Headgasket replacement, relatively doable?
