Good morning all, my MK6 85ps is suffering from some symptoms that I think I have narrowed down to some/a faulty injectors but I’d just like a sanity check before I start going too mad! So to begin with it sounds very happy at high revs and when it makes this tally noise it is like a switch turning on. I’ll go up through the Rev range and it’ll suddenly change to this noise. I also have an exhaust leak somewhere in the engine bay that I am yet to find and this may be contributing.
My next issue is when I switch the engine off, I get quite a strong shudder right as the engine comes to a stop. So much so that I have heard it rock the van enough to make the handbrake squeak at the rear wheels. Is this likely to be because there is an imbalance of fuel going between the injectors or is it likely to be an engine mount issue? I do believe one of my mounts is slightly duff because when I throttle off there is a thump and on occasion there is a thump when engaging the clutch. However when I grab the engine and try rocking it there is no movement at all.
Does anyone think they could help shed some light on this for me as I don’t want to fit a new mount to have it wrecked by the strong shudder on shutdown etc. Any help will be massively appreciated!
