dan83590 wrote:Right, not good news.
The fuel pump is worn and there is not a chance I can afford the cost to have the garage repair the darned thing.
So, tell me...
Is the fuel pump a job that can be done at home?
Is there a write up anywhere?
I had hoped i would never have to do driveway repairs again but hey ho, sh*t happens!
Unlikely the pump has died, is this what your mechanic said..?? I'm guessing it's probably just the timing solenoid, this can be done at home....many have done it. It's worth checking to see if it is the solenoid first before throwing money at a pump you may not need.
There's two different pumps depending on which engine you have, VP30 for the lower ps ones and VP44 for the higher PS jobbies.
http://www.catcar.info/ford/?lang=en&l= ... NCsyNzI%3DLord Knobrot
