Sparky0196666 wrote:I'm in need of a reconditioned engine or replacement engine. Don't know what's best. Anyone got any idea of reputable reconditioners or dealers to sort. Thanks
Transit Sport Mk7 2009.
Sparky0196666 wrote:I think the injector 2 overfueled and now a compression issue in chamber. Mechanic seems to think best to overhaul it.
You'll be lucky, just get any 100ps or above low mileage engine and put your turbo and injectors on it if they're okSparky0196666 wrote:Hi all.
Does anyone know of any reliable reconditioned engines for MK7 140 sport? The Internet seems a minefield so any help would be gratefully received.
Thank you
Did you check out my solution to your problem mate , will be easier to find a lower ps engine at decent miles as long as its 100ps or higher you can use it's injectors if yours are fooked and only need to change to your electronic turbo onto new engineSparky0196666 wrote:Hi all. This is proving a nightmare. Any help would be very appreciated.
Thank you
Mark
andz327 wrote:Did you check out my solution to your problem mate , will be easier to find a lower ps engine at decent miles as long as its 100ps or higher you can use it's injectors if yours are fooked and only need to change to your electronic turbo onto new engineSparky0196666 wrote:Hi all. This is proving a nightmare. Any help would be very appreciated.
Thank you
Mark
I put a rod through the block of ma 130
Got a 60k mileage 100ps put my turbo on and there's no difference in performance mate
ANDZ
