Jordonjay wrote:I was thinking maybe go from above and remove the cam cover see if that give me any more room to play with
But I was hoping Some mine have a trick to make life easy never know
bambi mk 1 wrote:Remove the fan ,place a jack under the engine x member loosen the bolts on the x member drop the engine and you can play football between the engine and bulkhead A 15 mm spanner will do the job that way
Users browsing this forum: Google [Bot], Google Adsense [Bot], jww9999, shonkers
