jerryv wrote:Bit of an update. Been plugged into computer and not showing a single fault. Fuel is getting too injectors and back through return pipe. Coughes and farts with a quick squirt of easy start(not my idea by the way). Apparently both crank position and cam position sensors are working but not synced. A new cam chain was fitted about a month ago and were like a pair of old women checking, double checking, correct use of torque wrench, every thing by the book. Still no sign of engine wanting to fire up. Something stupid or am I looking at a new top end possibly???
knobby1 wrote:jerryv wrote:Bit of an update. Been plugged into computer and not showing a single fault. Fuel is getting too injectors and back through return pipe. Coughes and farts with a quick squirt of easy start(not my idea by the way). Apparently both crank position and cam position sensors are working but not synced. A new cam chain was fitted about a month ago and were like a pair of old women checking, double checking, correct use of torque wrench, every thing by the book. Still no sign of engine wanting to fire up. Something stupid or am I looking at a new top end possibly???
Hmmm....the de-synch of cam and crank doesn't sound too good....I wonder if the chain has jumped..??
jerryv wrote:Its done 1600 miles since new cam chain kit was fitted. It wasn’t being thrashed, just sat at a very sedate 60-65mph on the motorway. I suppose something could have failed. Should there be a lot of noise or a definite clatter and knocking when the cam timeing shifts enough to wreck the top end?
v8dave wrote:If there is no sync it will not start - its a deliberate choice in the ecu programming.
The only way around it is to re-establish sync.
jerryv wrote:v8dave wrote:If there is no sync it will not start - its a deliberate choice in the ecu programming.
Right, been on to the garage that is doing the job (it broke down 250miles away so couldn't stay with it) and after inspection, the tensioner had failed and timeing had jumped a couple of teeth.
Luckerly no damage was done to the rocker gear. New tensioner fitted, retimed and double checked, new crank sensor fitted, cam sensor working. It will spin over and run on easystart but won't fire up. For some reason its still showing as not synced. Any ideas as to what it might be, its being a real PITA.
p.s. all info ive passed on is second hand from what the garage told me
yaroslav wrote:Good evening. If the engine is running at a fast start, the repair could be damaged plates on the flywheel (for Siemens-Continental fuel system).
knobby1 wrote:yaroslav wrote:Good evening. If the engine is running at a fast start, the repair could be damaged plates on the flywheel (for Siemens-Continental fuel system).
It's a Denso fuel system.
bambi mk 1 wrote:knobby1 wrote:yaroslav wrote:Good evening. If the engine is running at a fast start, the repair could be damaged plates on the flywheel (for Siemens-Continental fuel system).
It can happen on both systems Knobby ,the pick up ring can come apart
