Hy, I have a problem on my 2007 Transit 2.2 QVFA EURO 4, 81 kW 210 000km
-when the engine is on idle speed sometimes it just turn off by itself
-when changing gear and the RPM goes under cca.1500-1800/min SOMETIMES there is no power, engine runs but no answer to the accelerator pedal
-when no answer to the accelerator pedal SOMETIMES the engine slowly starts to drowning and turn off and SOMETIMES it catches up and running agian normally
-after a restart everything is running properly
-diagnostics is showing only cooling fan module
-everything is happening only SOMETIMES and only if the weather is cold and the engine is hot
I tried to cut the EGR but no result.
Any ideas? thanks for the help
