by timewarptel » Mon Feb 18, 2019 7:01 pm
Hi guys....I have a mk 6 2.4 diesel rwd. Need some advise please. Gears are getting difficult, particularly 1st and reverse. Goes in ok, when engine off. Holding clutch down with engine running, there is a slight bit of creep, mainly in reverse. But I don’t think clutch slips when driving. Checked gearbox and it definitely needs topping up, which I,ve yet to do. Don’t seem like any fluid leaks, master reservoir has enough fluid. Will I need new clutch , ...is there any checks I can do to confirm this. When warmed up on a run, does get a tad easier to select gear, maybe putting it in 2nd before putting it in first, that sort of thing. Thanks, terry
