Decided my 2010 T300 115 steering wheel was getting really tired, to the point it would make your hands dirty everytime you drove the van so did a bit of research and found the Ford Focus C max has a nice leather wheel with alloy inserts so decided to fit that.
On it went and plugged in the airbag, buttoned it all up, tested it and the airbag light comes on with the ignition, goes out for 10 seconds or so, then pops back on again and stays on until you switch off.
I have tried another bag, 2005-2010 focus airbag but does the same thing.
Do I need the airbag light reset due to me swapping things about or is there a conflict regarding the C max/Focus airbag and the Transit?
Or do I need a specific airbag to sort this?
part number for the fitted airbag is 4M51 A042B85 CF 3ZHE
Thanks in advance.
