v8dave wrote:Body Control Module.
You found the fuse box behind the glovebox, behind that is the bcm. Sometimes refered to as the second fuse box or the passenger junction box if you have the owners manual.
viewtopic.php?f=40&t=49206
v8dave wrote:Does the headlamp flash work ?
Needs1975 wrote:I have checked F71, and its sound. I have also tried a new headlight switch, no joy with that either. As Jim suggested earlier, i earthed the relay and it clicked in fine, so the relay is ok. What do i check next?
