by KIPPERMAN72 » Tue Apr 16, 2019 11:20 pm
Hi....first post..been reading forum for a long time and had no need to ask before as usually find info been posted before tho can’t find an answer to this....I have a mk6 2001 2.4 rwd Motorhome....I have a leak on boost under load (hills etc)....I’ve located it to be the gasket on the egr valve so going to blank tomorrow...plate I ordered had a gasket which I take is for on the egr itself with plate behind...My question is do I need to also use a gasket on the backside of the plate on the pipe that bring the gas back up to the egr itself...in the past I done this and it improved things though didn’t use new gasket only original one and I think the problems returned as I can here hissing under dash near intake manifold...I’m also gonna look at the intake manifold seams if egr gasket doesn’t fix problem...Thanks Steve
