Rossgal wrote:Is there any way of testing the PRV?
I have no pressure in the fuel rail so is this the most likely cause? It doesnt leak fuel from it if I prime it up, fuel comes out the leak off pipes first.
There is a leak off pipe from the fuel pump, another from the prv and four from the injectors. They all connect together before the return line gets to the fuel filter.
If fuel comes out of the injector leak off ports when you prime it then it can only be getting there through the fuel pump and rail.
If it is coming out of the pipework it must be coming from the pump leak off if the injectors and prv are disconnected.
Have you cranked it with the prv leak off pipe disconnected?
The fuel rail and injection volumes are very small so very little fuel flow is needed to create lots of pressure.
You say the sync is good so you have diagnostics. What is the rpm when cranking? what is the fuel pressure?
Does the diagnostics offer a engine crank no start test, ford ids has this test.
On the transit the scv is open when unpowered, if it is unplugged you should get a fault code for it's control circuit and if the engine starts the fuel pressure will be too high.
Is the fuel pump turning when the engine is turned? Have a look in through the access cover on the timing cover.
