Just replacing the front O/S wheel bearing today, and Im having a mare trying to fit the new bearing back on the van. Bearing pressed on to the flange no issues, but the bearing carrier seems to be just too big to fit back in the hub. Ive tried three times, each time, cleaning down the hub with a rotary wire brush, and lubing up with plenty of copper slip. The machined part of the bearing slips in, I then fit the 5 torx bolts, but cant get the bearing carrier in the last quarter inch, no matter how hard I do up the bolts. I've always got the bearing carrier in before with out using the press. Is this a Friday one, just machined to the wrong tolerance ?
I'll get out the digital callipers tomorrow, but left it for today, as I felt like a drowned rat in the rain...
