Hi guys hope you are all well! Sorry for the sudden pause of events, unfortunately had to get the van moved and it’s now on the side of a field and I have finally had time to have another go at it! So I quick recap to date is, got the top apart, rocker ladder off and all valves appear to be fully closed, timing chain removed, over the past evening, I managed to get the gearbox off, well pushed back far enough to give me access to the clutch / dmf and from what I can see, there seems to be no issues, the dual mass part moves nice and free, there were some obvious signs of someone removing the gearbox fairly recently, maybe trying to diagnose the same fault! And I am still stuck with the crank not doing a full rotation, with the pulley off and one bolt put back in, it rotates from 11o’clock all the way around until about 7o’clock and then just stop dead, so I’m thinking maybe the next step would be either head off, or sump off?
Any type of input would be greatly appreciated!
Cheers guys
